[postgis-users] ST_Intersection
jj.wag at gmx.de jj.wag at gmx.de
Fri May 21 06:30:45 PDT 2010
Nicolas,
> Is the select used to create the view returning rows ?
yes, I want to get the intersected parts of the polygonlayer and the area (I
need the returned rows in a php application)
> Is this IsEmpty test necessary to validate there is an intersection ?
yes, because I want only the intersected rows
Jo
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, May 21, 2010 2:34 PM
Subject: Re: [postgis-users] ST_Intersection
>> Hi,
>> I have a polygon table (alk_flurstuecke) and create a view with a
>> 40-meter
>> buffer on an object:
>> CREATE VIEW buffer_flur_40 AS
>> SELECT gid, ST_SetSRID(st_buffer(the_geom,40), 31466 )
>> AS the_geom FROM alk_flurstuecke WHERE fkz = '0726900330002300000';
>> No problem, Ican see it in QGIS.
>> Now I try to make an intersection on this buffer-view with my table:
>> CREATE VIEW intersect_flur_40 (gid, flur, zaehler, nenner, the_geom) AS
>> SELECT p.gid, p.flur, p.zaehler, p.nenner,
>> ST_SetSRID(ST_Intersection(p.the_geom, b.the_geom) ,31466)
>> AS the_geom FROM alk_flurstuecke AS p, buffer_flur_40 AS b
>> WHERE p.fkz <> '0726900330002300000' AND IsEmpty
>> (ST_Intersection(p.the_geom, b.the_geom) ) = FALSE;
>> This view is created without errors too but there is no result. If I try
>> to
>> load the view in QGIS it diapears.
>> Any idea?
> Hi,
> Nicolas
> postgis-users mailing list
