[postgis-users] Check identical point
Nicklas Avén nicklas.aven at jordogskog.no
Sat May 22 06:46:04 PDT 2010
Oh, I saw my own typo (forget the arguments for pointdistance3d). the query should be
Select * from table1, table2
where table1.the_geom &&ST_Expand(table2.the_geom, 0.1) and
 table2.the_geom && ST_Expand(table1.the_geom, 0.1) and
pointdistance3d(table1.the_geom, table2.the_geom)<=0.1;
/Nicklas
2010-05-22 Nicklas Avén  wrote:
Hallo
>The ST_DWithin fuction will only check the 2d distance and not care it the points are far from each other in z direction.
>If you need to also check they are close in z-direction I guess the easiest way is to calculate the 3d distance between the points with Pythagorean theorem. The cleanest maybe is to make a function of it like this:
>create or replace function pointdistance3d(p1 geometry, p2 geometry)
>returns double precision as
>select sqrt((st_x($1)-st_x($2))^2 + (st_y($1)-st_y($2))^2 + (st_z($1)-st_z($2))^2);
>language 'sql';
>then to get some speed of it you can use st_dwithin to do a first index-based search. That is as said only a 2d calculation, but if the distance is more than your tolerance in 2d it will be also in 3d.
>I think the most effective way of doing this is to only do the bounding box comparison that is built into st_dwithin and then go straightly to the 3d calculation. That would look something like this if we use the tolerance 0.1 meters (requires based coordinate sytem):
>Select * from table1, table2 where table1.the_geom && ST_Expand(table2.the_geom, 0.1) and
>table2.the_geom && ST_Expand(table1.the_geom, 0.1) and pointdistance3d<=0.1;
>Hope that helps
>Nicklas
>Try:
>>   ST_DWithin(point1, point2, 0.00001)
>>-F
2010/5/22 eehab hamzeh <eehab40 at hotmail.com>
Hello
>>I want to check if two points are identical, the points has x,y,z coordinates and they are not exactly the same, i need to check the intersection between them with tolerance value. any direction of how to do that.
>>Thank
>>kind regards
>>Hotmail: Powerful Free email with security by Microsoft. Get it now.
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100522/5a99401d/attachment.html>
