[postgis-users] Create View From Spatial Table with libpq
郭家成 iron1103 at gmail.com
Mon May 24 00:14:32 PDT 2010
Thanks for your quick reply, I just did some tests.
select oid,typname from pg_type where typname='geometry' or typname='bytea';
oid       typname
17        bytea
16402   geometry
But Postgre gives me another error message, I list what I tested
Test 1:
   create view "v" as select * from "t" where ST_Intersects("geocol", $1);
   Oid paramtypes[1]={16402};
   The Errmsg: There is no parameter $1
 Test 2:
   Oid paramtypes[1]={17};
 Test 3:
$1::geometry);
 Test 4:
ST_GeomFromWKB($1::bytea));
The 4 tests above all return PGRES_FATAL_ERROR and same errmsg,
Here is another 4 tests:
 Test 5:
 Test 6:
 Test 7:
   select * from "t" where ST_Intersects("geocol", $1::geometry);
 Test 8:
Test 5 to 8 are return PGRES_TUPLES_OK, and even Test 9.
Test 9:
ST_GeomFromWKB($1::geometry));
   ::geometry does not match to paramtypes[1], but Test 9 still return OK
So, everything works fine without "CREATE VIEW", weird.
2010/5/24 Mike Toews <mwtoews at gmail.com>
> 2010/5/23 郭家成 <iron1103 at gmail.com>
>> Hi Mike,
>> Thanks for your reply, but it still doesn't work.
>> The key point possibly lies in *Oid paramtypes[1]={0}*,
>> Where can I find the ParamType of Geometry or Bytea?
> They are defined in the system tables:
> select oid, * from pg_type where typname='geometry' or typname='bytea';
> I'm not sure if the oid for geometry is constant with different
> installations (mine is 16892). Bytea is always 17, since it is hard-coded
> in src/include/catalog/pg_type.h
> -Mike
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100524/f5603c11/attachment.html>
