[postgis-users] ST_DWithin with radius 0.000001
nguyen liem liemnguyendl at gmail.com
Tue May 25 02:10:57 PDT 2010
Hi Nicklas
sr for the mistake  ... field but it *was not* improve the perofrmance for
ST_intersect
Cheers
On Tue, May 25, 2010 at 3:53 PM, nguyen liem <liemnguyendl at gmail.com> wrote:
> Hi Nicklas
> my dataset about 100.000 rows and after run my query i get about 15.000
> rows. I has created index for "geom" field but it was improve the
> perofrmance for ST_intersect
> I used SRID 4326, but I don't know how to convert from degree to meter.
> Cheers
> On Tue, May 25, 2010 at 3:43 PM, Nicklas Avén <nicklas.aven at jordogskog.no>wrote:
>> Ok
>> The distance of 0.00001 degree in east west direction will vary depending
>> on how far from the equator you are.
>> How many points is there in your dataset?
>> Do you see if the index is used?
>> /Nicklas
>> 2010-05-25 nguyen liem wrote:
>> Hi Nicklas
>> >Actually the points can be outside the polygon and returning true but it
>> can be tolerance about 1 meters outside.
>> >I'm using SRID: 4326. I would like to know 0.00001 with the projection
>> 4326 is equal 1 meter or not ?
>> >I used ST_Intersects (geom, geometry); but it's really slow, I don't know
>> why.
>> >I also used ST_Dwithin (geom, geometry, 0) and the result is empty, i
>> couldn't found any neighbour.
>> >Cheers
>> On Tue, May 25, 2010 at 3:22 PM, Nicklas Avén <nicklas.aven at jordogskog.no>
>> wrote:
>> Hallo
>> > What you are doing with ST_Dwithin is to check if your geom and geometry
>> have parts closer to (or exactly) 0.00001 mapunits from eachother. If you
>> are using a meter based SRID then you are checking if they are within
>> 0.00001 meters from eachother. So actually in this case your points can be
>> just outside the polygon and returning true. If you want to use st_dwithin
>> you should use 0 instead of 0.00001 . But I don't think that is any faster
>> than ST_Intersects. The important thing in both cases is to have working
>> spatial indexes.
>> > put an index on geom column in my_neighbour table and analyze the table.
>> > Create index idx_mn_geom
>> > on my_neighbour
>> > using gist(geom);
>> > analyse my_neighbour;
>> > Then try:>
>> > SELECT id, geom
>> > FROM my_neighbour
>> WHERE ST_Intersects (geom, geometry);
>> > I guess that is the best solution.
>> > Hope that helps
>> > Nicklas>
>> > Hi all
>> > >At the first time i used ST_Contains but it take a long time, so I used
>> ST_Dwithin to improve the performance for the query statement but i don't
>> know it is correct or not.
>> > >I would like to know my points are within in polygon or not:
>> > >SELECT id, geom
>> > >FROM my_neighbour
>> > >WHERE ST_Dwithin (geom, geometry, 0.00001)
>> > >geometry: is a polygon(input parameter).
>> > >0.00001: I means the radius of geometry is 1 meters, is it right?
>> > >Cheers.
>> > >Liem Nguyen
>> > >Developer
>> > >Axon Active Corp.
>> > >Direct Line      : +84 38 948 4645
>> > >Fax                  : +84 38 811 3489
>> > > Mobile Phone  : +84 168 994 8897
>> > >Skype ID         : liemnguyendl2204
>> > >Email               : liem.nguyen at axonactive.net /
>> > Web Site          : axonactive.vn>
>> > >Address           : 87 Thang Long Street,Gate 2 Ward 4,
>> > >                          Tan Binh District, HCM city, Vietnam.
>> >_______________________________________________
>> > postgis-users mailing list
>> >postgis-users at postgis.refractions.net
>> >postgis.refractions.net/mailman/listinfo/postgis-users
>> >Liem Nguyen
>> >Developer
>> >Axon Active Corp.
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Liem Nguyen
> Developer
> Axon Active Corp.
> Email               : liem.nguyen at axonactive.net / liemnguyendl at gmail.com
> Web Site          : http://axonactive.vn
Liem Nguyen
Developer
Axon Active Corp.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100525/0f6f7882/attachment.html>
