[postgis-users] ERROR: could not load library "/usr/local/pgsql/lib/postgis-1.5.so
Paul Ramsey pramsey at opengeo.org
Thu May 27 07:39:10 PDT 2010
Yes, after installing a new library, run ldconfig as root. This
informs the linker to check for new libraries (in the directories
listed in /etc/ld.so.conf)
P
On Thu, May 27, 2010 at 10:31 AM, Kai Behncke <Kai-Behncke at gmx.de> wrote:
> Hi you
>> I bet on missing ldconfig after libproj install.
>> --strk;
> You mean I need to do a ldconfig after that??
> (that iscompletely new for me.....)
> Indeed I did with that library "configure", "make", "make install".
> Best regards, Kai
> GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
> postgis-users mailing list
