[postgis-users] ERROR: could not load library "/usr/local/pgsql/lib/postgis-1.5.so
Kai Behncke Kai-Behncke at gmx.de
Thu May 27 07:51:40 PDT 2010
Hi all,
thank you again.
I again installed geos (3.2.2) and proj (4.7) and after each I did a "ldconfig", but even though
the error appears:
CREATE OR REPLACE FUNCTION st_spheroid_in(cstring)
        RETURNS spheroid
        AS '$libdir/postgis-1.5','ellipsoid_in'
        LANGUAGE 'C' IMMUTABLE STRICT;
ERROR:  could not load library "/usr/local/pgsql/lib/postgis-1.5.so": /usr/local/pgsql/lib/postgis-1.5.so: undefined symbol: GEOSHausdorffDistance
That is really weird??
Best regards, Kai
-------- Original-Nachricht --------
> Datum: Thu, 27 May 2010 10:39:10 -0400
> Von: Paul Ramsey <pramsey at opengeo.org>
> An: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Betreff: Re: [postgis-users] ERROR: could not load library	"/usr/local/pgsql/lib/postgis-1.5.so
> Yes, after installing a new library, run ldconfig as root. This
> informs the linker to check for new libraries (in the directories
> listed in /etc/ld.so.conf)
> P
> On Thu, May 27, 2010 at 10:31 AM, Kai Behncke <Kai-Behncke at gmx.de> wrote:
> > Hi you
> >> I bet on missing ldconfig after libproj install.
> >> --strk;
> > You mean I need to do a ldconfig after that??
> > (that iscompletely new for me.....)
> > Indeed I did with that library "configure", "make", "make install".
> > Best regards, Kai
> > GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> > Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
