[postgis-users] ERROR: could not load library "/usr/local/pgsql/lib/postgis-1.5.so
Kai Behncke Kai-Behncke at gmx.de
Thu May 27 08:08:48 PDT 2010
Hi Paul, Mark, strk
thank you very much :-)
I deleted the older geos-version. Now verything runs finely :-)
Best regards, Kai
-------- Original-Nachricht --------
> Datum: Thu, 27 May 2010 15:57:46 +0100
> Von: Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
> An: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Betreff: Re: [postgis-users] ERROR: could not load	library	"/usr/local/pgsql/lib/postgis-1.5.so
> Paul Ramsey wrote:
> > Sounds like you have an older version of GEOS floating around somewhere.
> > find / -name "libgeos_c.*"
> > P.
> Yeah, that looks about right from Kai's earlier email:
>   linux-gate.so.1 =>  (0xffffe000)
>          libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0xb7ea6000)
>          libproj.so.0 => /usr/local/lib/libproj.so.0 (0xb7e73000)
>          libxml2.so.2 => /usr/lib/libxml2.so.2 (0xb7d59000)
>          libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7c28000)
>          libgeos.so.2 => /usr/lib/libgeos.so.2 (0xb7b27000)
>          libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb7a42000)
>          libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7a1c000)
>          libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7a11000)
>          libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0xb7a0d000)
>          libz.so.1 => /usr/lib/libz.so.1 (0xb79f9000)
>          /lib/ld-linux.so.2 (0x80000000)
> Looks as if there is a GEOS v2 already installed (probably installed via
> a package manager) causing problems.
> HTH,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-users mailing list
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
