[postgis-users] PostGIS: make check works, but I can't manually create a spatial database
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri May 28 08:11:36 PDT 2010
samclemmens wrote:
> Unfortunately, I get the following:
> postgres=# SELECT postgis_full_version();
> ERROR:  function postgis_full_version() does not exist
> LINE 1: SELECT postgis_full_version();
> HINT:  No function matches the given name and argument types. You might need
> to add explicit type casts.
Okay so something has gone wrong somewhere. Firstly, after "make check",
did you run "make install"? Secondly, what happens if you load the
postgis.sql file into a brand new database?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
