[postgis-users] PostGIS: make check works, but I can't manually create a spatial database
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri May 28 08:47:07 PDT 2010
samclemmens wrote:
> I ran make install after make check, and received the output below.  There
> was no confirmation that it installed properly or not.  I tried creating
> another spatial database using the same commands, but to no avail.  ---Same
> issue.
The "make install" output looks good. Are you sure you get *exactly* the
same error as before when installing into a fresh database? The part of
the log we need to see when installed into a fresh database are the set
of lines just before and just after the first ERROR appears. Please drop
the database and try again posting the relevant output.
The only other thing I can think of is that someone has installed
another version of PostGIS into the template1 database so that it gets
automatically added to any new database.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
