[postgis-users] PostGIS: make check works, but I can't manually create a spatial database
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri May 28 09:08:58 PDT 2010
samclemmens wrote:
> I dropped the db and recreated it...and this time it worked.  I get the
> following, which, I'm assuming, means I'm good to go...?
> testdb1=# SELECT postgis_full_version();
>  POSTGIS="1.5.0SVN" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August
> 2008" LIBXML="2.7.6" USE_STATS
> (1 row)
Yep; that looks good to me :)
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
