[postgis-users] Hanging Postgres 9.0 + Postgis 1.5.2 on windows
Paragon Corporation lr at pcorp.us
Sat Oct 2 16:26:46 PDT 2010
Andrea,
We did some more tests.  I think its something in the new config that is too
high or low.
If we copy our default PostgreSQL 8.4.4 postgresql.conf to our PostgreSQL
9.0 install, your script  works fine.
Thanks,
Leo and Regina
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paragon
Corporation
Sent: Saturday, October 02, 2010 7:18 PM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] Hanging Postgres 9.0 + Postgis 1.5.2 on windows
Andrea,
We tested too on 9.0 and our 8.4.4 install and we came up with same results
as you
Crashes on 9.0
Works fine 0n 8.4.4
Both running on Windows 7 with PostGIS 1.5.2, GEOS 3.2.2
I suppose it could just be a setting in the config that is too high or low
on 9.0
Anyrate does seem to be a PostgreSQL 9.0 issue.  Whether its isolated to
windows is  a different question.
Maybe Paul, Mark, or Kevin or someone on Linux with 9.0 installed can test .
Thanks,
Regina
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andrea
Peri 2007
Sent: Saturday, October 02, 2010 7:03 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Hanging Postgres 9.0 + Postgis 1.5.2 on windows
I've test again.
>I guess to rule out PostGIS as the culprit -- you could try upgrading
>your Postgres 8.4.4 to 1.5.2 (a quick way is to copy over the
>postgis-1.5.dll ,libxml, and geos binaries in bin folde) -- making sure
>to backup your existing and restart.  Binaries are available Postgis
>1.5
8.4 binaries.
>http://www.postgis.org/download/windows/#windbinaries
The execution of the script on the PG8.4.4 with Postgis 1.5.2 terminate
without any problem.
As more test,
I try to re-install PG9.0 + Postgis 1.5.2.
But without any result.
PG 9.0 crash again with that script sql.
Regards,
Andrea.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
