[postgis-users] shp2pgsql 1.5 is crashing
Stephen Woodbridge woodbri at swoodbridge.com
Mon Oct 18 05:57:23 PDT 2010
On 10/18/2010 5:07 AM, Sebastian E. Ovide wrote:
> Is there any reason why not to use gdal ogr2ogr ?
Much of the time I do not need to transform the geometry so I have not
loaded gdal/ogr on the system. The other reason is that I have loads of
scripts that use shp2pgsql because that is all I need in most cases.
So with that I have never actually had to use ogr2ogr to load the data
into postgis, but there is no technical reason not to.
-Steve
> On Thu, Oct 14, 2010 at 7:03 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 10/14/2010 12:02 PM, Mark Cave-Ayland wrote:
>         Stephen Woodbridge wrote:
>             Hi all,
>             I'm running into a crashing problem with shp2pgsql on 1.5
>             release on a
>             CentOS 5
>             This crashes:
>             shp2pgsql -s 4326 -c -D Hydrants_4326.shp data.hydrants
>             This works ok:
>             shp2pgsql -s 4326 -c -D -N skip Hydrants_4326.shp data.hydrants
>             File loads ok in OpenEV and runs through ogr2ogr without a
>             problem.
>             -Steve W
>         Hi Steve,
>         If you're not already running 1.5.2, I'd try that as I seem to
>         remember
>         there were a couple of bugfixes that might be relevant here.
>     Hi Mark,
>     I sort of thought there might have been some fixes, but could not
>     verify that and did not realize I was back a version.
>     Thanks,
>       -Steve
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>     http://postgis.refractions.net/mailman/listinfo/postgis-users
> Sebastian E. Ovide
