[postgis-users] ST_AsBinary
Ravi ravivundavalli at yahoo.com
Sun Oct 31 05:34:31 PDT 2010
Michaël, Regina and Leo,
thank you for making life a little easier. It works by replacing
postgresql-8.3-603.jdbc3.jar
by
postgresql-9.0-801.jdbc3.jar
But kindly suggest in what FOSS4G tools ST_AsBinary can work.
Ravi Kumar
--- On Sun, 31/10/10, Paragon Corporation <lr at pcorp.us> wrote:
Subject: Re: [postgis-users] ST_AsBinary
To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
Date: Sunday, 31 October, 2010, 8:33 AM
Correct.  In fact we even has this as our #1 FAQ for
1.5
http://www.postgis.org/documentation/manual-1.5SVN/ch03.html#id2872420
Thanks,
Regina and Leo
http://www.postgis.us
postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Michaël Michaud
Sent: Saturday, October 30, 2010 4:54
PM
To: PostGIS Users Discussion
ST_AsBinary
Hi Ravi,
Did you try to update your jdbc driver
Again, there is a link here to download it :
http://jdbc.postgresql.org/download.html
You
should download http://jdbc.postgresql.org/download/postgresql-9.0-801.jdbc3.jar
Then,
you have to go in your OpenJUMP intallation directory and replace
by
If
you're using java6, you should be able to use 9.0-801
JDBC 4 instead of 9.0-801
JDBC 3
Note that I haven't yet install postgresql 9.0 to check
everything is fine, but it comes from a discussion I had with postgis
developpers that something changed in the postgresql 9.0 byte array format,
which is the reason why a new driver is required.
Hope that
helps
Michaël
Le 30/10/2010 21:06, Ravi a écrit :
      ST_AsBinary
Other that OpenJUMP, suggest which FOSS4G
        tool can be used.
Finding some road blocks using
PostGIS and
        Seeing it on OpenJUMP.
Ravi Kumar
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101031/e061ec44/attachment.html>
