[postgis-users] Buffering a convexhull
Brian Sanjeewa Rupasinghe jinkabs at gmail.com
Fri Oct 15 03:36:15 PDT 2010
I used the following query to make a buffer of 1m iutward to a convexull
created by union of a set of polygons. But it gives an error.Why?
SELECT ST_As_Text(ST_Buffer (foo.the_geom, 1)) from (select
(ST_ConvexHull(ST_Union(the_geom))) from building_poly) As foo;
Sanjjewa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101015/b4b505db/attachment.html>
