[postgis-users] Input versus output geometry
Alex Zepeda zipzippy at sonic.net
Wed Sep 1 13:42:39 PDT 2010
Recently I used pg_dump to export the output of a table with a geometry
column representing a bounding box.  There's an exclusion constraint on
that table such that rows with overlapping bounding boxes that contained
two other overlapping columns would be rejected.  As it turned out I
could insert the data, export it, but *not* play it back into another
instance of postgres as the exclusion constraint barfed.
A bit of back and forth with some of the postgres guys revealed that the
output does not recreate the exact input.
Is this the intended behaviour?  If so, is there any way to extract a
more precise representation of the geometry column?
This was with Postgres 9.0rc1 and Postgis 1.5.2 SVN r5851.
gisttest2=# select
ST_expand(setsrid(makepoint(-122.50367,37.74189),4326), 0.00004);
                       st_expand
0103000020E61000000100000005000000C32ADEC83CA05EC0D044D8F0F4DE4240C32ADEC83CA05EC0ECF5EE8FF7DE424035D252793BA05EC0ECF5EE8FF7DE424035D252793BA05EC0D044D8F0F4DE4240C32ADEC83CA05EC0D044D8F0F4DE4240
(1 row)
gisttest2=# select
ST_expand(setsrid(makepoint(-122.50376,37.74185),4326), 0.00004);
                       st_expand
0103000020E6100000010000000500000063EE5A423EA05EC042EC4CA1F3DE424063EE5A423EA05EC05E9D6340F6DE4240D595CFF23CA05EC05E9D6340F6DE4240D595CFF23CA05EC042EC4CA1F3DE424063EE5A423EA05EC042EC4CA1F3DE4240
(1 row)
gisttest2=# select
ST_expand(setsrid(makepoint(-122.50367,37.74189),4326), 0.00004) &&
  ?column?
  f
(1 row)
gisttest2=# select
'0103000020E61000000100000005000000C32ADEC83CA05EC0D044D8F0F4DE4240C32ADEC83CA05EC0ECF5EE8FF7DE424035D252793BA05EC0ECF5EE8FF7DE424035D252793BA05EC0D044D8F0F4DE4240C32ADEC83CA05EC0D044D8F0F4DE4240'::geometry
gisttest2-#
'0103000020E6100000010000000500000063EE5A423EA05EC042EC4CA1F3DE424063EE5A423EA05EC05E9D6340F6DE4240D595CFF23CA05EC05E9D6340F6DE4240D595CFF23CA05EC042EC4CA1F3DE424063EE5A423EA05EC042EC4CA1F3DE4240'::geometry;
  ?column?
  t
(1 row)
- alex
