[postgis-users] Error checking trunk version
Olivier Courtin olivier.courtin at oslandia.com
Sun Sep 5 01:06:25 PDT 2010
On Sep 5, 2010, at 5:43 AM, Nicklas Avén wrote:
Nicklas,
> The difference is 1 extra digit in the expected result compared to
> Andreas result. I get the same result as Andrea on PostGISonline which
> is 32 bit Ubuntu. The result in "expected" I had from a 64 bit ubuntu
> box.
You should consider using cunit instead,
Have a look for instance to cu_measures, and
do_test_mindistance2d_tolerance function...
HTH,
Olivier
