[postgis-users] (no subject)
Kevin Neufeld kneufeld at refractions.net
Thu Sep 16 08:53:04 PDT 2010
It's true that if you create a table in this manner, the geometry column
of table2 won't be registered with the geometry column metadata
information listed in geometry_columns (which is often needed by
third-party applications).  Further, the table2 table will be missing
the usual 3 sanity check constraints usually placed on a geometry
column.  In other words, after table2 has been created, you could
theoretically update the geometry column to contain mixed geometry
types, projections, or dimensions - a sure source of bugs in any
application.
Populate_Geometry_Columns() addresses these issues.
http://postgis.refractions.net/docs/Populate_Geometry_Columns.html
SELECT Populate_Geometry_Columns('table2'::regclass);
Cheers,
Kevin
On 9/16/2010 8:11 AM, Henri De Feraudy wrote:
> The SQL Cookbook recommends the following SQL code to copy a table's
> structure from table1 to table2:
> create table table2 as select * from table1 where 1=0;
> What's great about this is that it obviates the need to know the
> structure of table1.
> But what if table1 has a geometry column?
> As geometry column existence is recorded in some other tables it
> doesnt look as if the above trick is doing enough.
> What's your suggestion?
> Henri
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100916/986e2dd2/attachment.html>
