[postgis-users] combine serveral parts of the country
Thomas Andres andres85thomas at gmail.com
Wed Sep 22 04:33:20 PDT 2010
Hi Ralf,
yes the second dataset was imported with -append.
I didn't explain well:
Ogr2ogr creates the ogc_fid by incrementing, there aren't double ogc_fid s.
But the Interlis himself tells ogr2ogr to create the linking attributes and
fill them with the numbers written in the ITF-File.
('Parcelle_von' is in the right table and '_tid' in the left table). And
it's here, where I have the collision when I'm importing the second
dataset... it's normal, because
The ITF-Files were written be different persons. They re-used the same
links...
Gr
Thomas, aus dem Wallis
-----Ursprüngliche Nachricht-----
Von: Ralf Suhr [mailto:Ralf.Suhr at itc-halle.de]
Gesendet: Mittwoch, 22. September 2010 11:28
An: PostGIS Users Discussion
Cc: Thomas Andres
Betreff: Re: [postgis-users] combine serveral parts of the country
Hi Thomas,
ogc_fid can't exists twice. It is the primary key from ogr2ogr. Did you
import
your secound dataset with ogr2ogr -append?
Gr
Ralf
Am Mittwoch 22 September 2010 09:15:49 schrieb Thomas Andres:
> Salü Ralf,
> Thank you for your answer.
> -    When I use ogc_fid as primary key, I can’t import a second village,
> because the IDs of their features were created by different offices,
> different applications, so it’s possible that the same feature-id exists
> twice.
> -    When I use shemas, I have to rewrite all SQL Querys.  Select blabla
> from village1.parcelles Union all select blabla from village2.parcelles
> Union all etc
 This can become very long J
> If it’s possible, I would like that postgres sees, that the feature-id
>  which ogr2ogr is importing now, already exists,
 so give to the new
>  feature a new feature-id, and at the same time he checks all foreign keys
>  and adjust them to the new feature-id to maintain the link. (J
>  complicated)
> Is there a easy solution?
> Thank you for your help.
> Salutation from “Chuchichäschtli”
> P.S.: Chuchichäschtli is a box in the kitchen
> Hi Chuchichäschtli,
> you can use ogc_fid as primary key from your tables or create on schema
for
> one village.
> What "Chuchichäschtli" mean in german?
> Gr
> Ralf
> Am Montag 20 September 2010 09:34:11 schrieb Thomas Andres:
> > Dear List,
> > i’m Swiss and my English isn’t the most best. Even, I will try the
> > explain
> > You my problem. Perhaps You will understand J
> > In Switzerland the parts of the country were measured by different
> offices.
> > The informations of the terrain (parcelles, rows, lakes, jungle etc
> ) are
> > exchanged by Interlis Files (*.itf).
> > With ogr2ogr this files can be imported into a Postgres Database.
> > When You import only one file, it’s not a problem. Every Line, Point,
> > Polygone and so on, has its own Feature-Id, which can be linked with
> >  another feature.
> > I.e.: The geometry of a parcelle is linked with his number.
> > Now, when I would like add a second village to my GIS, in the same
> >  Database, to be loaded in Mapserver with a mapfile layer
>  the parcelle
> >  with the same Feature ID will appear twice
>  so the link to the number of
> >  the parcelle is wrong
> > What I made in a first time: after have imported the first village, I
add
> >  to the primary and foreign keys, which I really I’m going to use in my
> GIS
> >  a Char (‘a’ in example)
>  by using PostgreSQL
>  only after I imported the
> >  second file. This is a solution which works, but not for long time J
> > I asked me, or better: I ask You, if there isn’t a mechanism in PostGIS
> > or
> > PostgreSQL which is specially implemented for this kind of collage
>  Some
> > kind of namespaces or
>  I don’t know
>  You understand =-) ?
> > Thänk You very much for Your help.
