[postgis-users] combine serveral parts of the country
Thomas Andres andres85thomas at gmail.com
Wed Sep 22 06:23:47 PDT 2010
Hi Ralf,
the solution with the views is interesting.
Thank you very much
-----Ursprüngliche Nachricht-----
Von: Ralf Suhr [mailto:Ralf.Suhr at itc-halle.de]
Gesendet: Mittwoch, 22. September 2010 14:17
An: Thomas Andres
Betreff: Re: [postgis-users] combine serveral parts of the country
Hi Thomas,
now I know what you mean. ogr2ogr create more then one table per import.
You can import dataset in a temporary schema, look for the highest value for
Parcelle_von, update the temporary tables (Parcelle_von, _tid) and copy
temorary data to the main tables. This will only work for importing data not
for updating katastral data.
The other way is to use seperat schemas,  the same sequence
'parcels_ogc_fid_seq' for all parcel tables and a view like
Create View parcels AS
  Select * FROM kanton1.parcels
  UNION ALL
  Select * FROM kanton2.parcels
Gr
Ralf
Am Mittwoch 22 September 2010 13:33:20 schrieben Sie:
> Hi Ralf,
> yes the second dataset was imported with -append.
> I didn't explain well:
> Ogr2ogr creates the ogc_fid by incrementing, there aren't double ogc_fid
s.
> But the Interlis himself tells ogr2ogr to create the linking attributes
and
> fill them with the numbers written in the ITF-File.
> ('Parcelle_von' is in the right table and '_tid' in the left table). And
> it's here, where I have the collision when I'm importing the second
> dataset... it's normal, because
> The ITF-Files were written be different persons. They re-used the same
> links...
> Gr
> Thomas, aus dem Wallis
> Gesendet: Mittwoch, 22. September 2010 11:28
> An: PostGIS Users Discussion
> Cc: Thomas Andres
> Hi Thomas,
> ogc_fid can't exists twice. It is the primary key from ogr2ogr. Did you
> import
> your secound dataset with ogr2ogr -append?
> Gr
> Ralf
> Am Mittwoch 22 September 2010 09:15:49 schrieb Thomas Andres:
> > Salü Ralf,
> > Thank you for your answer.
> > -    When I use ogc_fid as primary key, I can’t import a second village,
> > because the IDs of their features were created by different offices,
> > different applications, so it’s possible that the same feature-id exists
> > twice.
> > -    When I use shemas, I have to rewrite all SQL Querys.  Select blabla
> > from village1.parcelles Union all select blabla from village2.parcelles
> > Union all etc
 This can become very long J
> > If it’s possible, I would like that postgres sees, that the feature-id
> >  which ogr2ogr is importing now, already exists,
 so give to the new
> >  feature a new feature-id, and at the same time he checks all foreign
> > keys and adjust them to the new feature-id to maintain the link. (J
> >  complicated)
> > Is there a easy solution?
> > Thank you for your help.
> > Salutation from “Chuchichäschtli”
> > P.S.: Chuchichäschtli is a box in the kitchen
> > Hi Chuchichäschtli,
> > you can use ogc_fid as primary key from your tables or create on schema
> for
> > one village.
> > What "Chuchichäschtli" mean in german?
> > Gr
> > Ralf
> > Am Montag 20 September 2010 09:34:11 schrieb Thomas Andres:
> > > Dear List,
> > > i’m Swiss and my English isn’t the most best. Even, I will try the
> > > explain
> > > You my problem. Perhaps You will understand J
> > > In Switzerland the parts of the country were measured by different
> > offices.
> > > The informations of the terrain (parcelles, rows, lakes, jungle etc
> > ) are
> > > exchanged by Interlis Files (*.itf).
> > > With ogr2ogr this files can be imported into a Postgres Database.
> > > When You import only one file, it’s not a problem. Every Line, Point,
> > > Polygone and so on, has its own Feature-Id, which can be linked with
> > >  another feature.
> > > I.e.: The geometry of a parcelle is linked with his number.
> > > Now, when I would like add a second village to my GIS, in the same
> > >  Database, to be loaded in Mapserver with a mapfile layer
> >  the parcelle
> > >  with the same Feature ID will appear twice
> >  so the link to the number of
> > >  the parcelle is wrong
> > > What I made in a first time: after have imported the first village, I
> add
> > >  to the primary and foreign keys, which I really I’m going to use in
my
> > GIS
> > >  a Char (‘a’ in example)
> >  by using PostgreSQL
> >  only after I imported the
> > >  second file. This is a solution which works, but not for long time J
> > > I asked me, or better: I ask You, if there isn’t a mechanism in
> > > or
> > > PostgreSQL which is specially implemented for this kind of collage
> >  Some
> > > kind of namespaces or
> >  I don’t know
> >  You understand =-) ?
> > > Thänk You very much for Your help.
