[postgis-users] geos proj stats modules all = v.1
Rebecca Cooper rmcooper at live.com
Tue Sep 28 06:24:34 PDT 2010
I have recently tried installing postgesql 8.4 with PostGIS 1.5 ( now clean installs with v 1.4 instead ) onto to separate machines using the windows installer.  I have only now realised that the buffer function is not available, despite being in the functions list.  I checked the postgis_version() and the result was "1.4 USE_GEOS=1 USE_PROJ=1 USE_STATS=1".
The last time I installed this at work the correct geos module etc were installed.  I have looked around and I can't find anything to say how I can manually change this.  I believe it should be looking at the corrrect library as I found in the bin folder the  libgeos-3-2-0.dll, libgeos_c-1.dll, libproj.dll files, but I don't know anything about them or how they are being referenced, other thatn one says 3.2 on it.  I have tried looking for a postgis_config file, but I don't think that is something available to windows users(?)
Sorry for being so clueless, but I am worried as I have a deadline on friday and need to be able to use this functionality!
many thanks,
Rebecca
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100928/56c9814b/attachment.html>
