[postgis-users] Postgis Installation Error
vikashvikky vikashtalanki at gmail.com
Thu Apr 7 14:26:54 PDT 2011
Hi Jorge,
    Thanx for your reply. I have tried what you said, this time its somewhat
better than previous but still some problem, When I make check I am getting
unning tests
 loader/Point.............. ok
 loader/PointM.............. ok
 loader/PointZ.............. ok
 loader/MultiPoint.............. ok
 loader/MultiPointM.............. ok
 loader/MultiPointZ.............. ok
 loader/Arc.............. ok
 loader/ArcM.............. ok
 loader/ArcZ.......... ok
 loader/Polygon.............. ok
 loader/PolygonM.............. ok
 loader/PolygonZ.............. ok
 regress. ok
 regress_index. ok
 regress_index_nulls. ok
 lwgeom_regress. ok
 regress_lrs. ok
 removepoint. ok
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. ok
 measures. ok
 long_xact. ok
 ctors. ok
 sql-mm-serialize. ok
 sql-mm-circularstring. ok
 sql-mm-compoundcurve. ok
 sql-mm-curvepoly. ok
 sql-mm-general. ok
 sql-mm-multicurve. ok
 sql-mm-multisurface. ok
 geojson. ok
 gml. ok
 svg. ok
 kml. ok
 in_gml. ok
 in_kml. ok
 regress_ogc. ok
 regress_ogc_cover. ok
 regress_ogc_prep. ok
 regress_bdpoly. ok
 regress_proj. ok
 dumppoints. ok
 wmsservers. ok
 tickets. failed (diff expected obtained: /tmp/pgis_reg_6910/test_47_diff)
 regress_buffer_params. ok
 hausdorff. ok
Run tests: 49
Failed: 1
make[1]: Leaving directory `/sources/postgis/postgis-1.5.0SVN/regress'
And getting the same error when I try to create template_postgis db.
View this message in context: http://old.nabble.com/Postgis-Installation-Error-tp31336778p31346600.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
