[postgis-users] Need help with a query to assign attributes to lines the intersect multiple polygons
    Birgit Laggner
    birgit.laggner at vti.bund.de
    Tue Apr 26 01:51:06 PDT 2011
Hi Steve,
I thought about your problem and I would solve it with distinct on  -
like this:
update line set poly_att=sel.poly_att from (select distinct on
(a.line_id) a.line_id, b.poly_att from line a inner join polygons b on
a.the_geom && b.the_geom where st_intersects(a.the_geom,b.the_geom)
order by a.line_id, st_length(st_intersection(a.the_geom, b.the_geom))
desc) sel where line.line_id=sel.line_id;
Hope that helps,
Birgit.
Am 25.04.2011 16:24, schrieb Stephen Woodbridge:
> Hi all,
> I have a table a line and a table of polygons.
> I would like to come up with a query that allow me to link the lines
> to the polygon where most of the length of the line falls into that
> polygon.
> The problem is that the lines may overlap or touch more than one
> polygon. So I can do this in a stored procedure where I iterate
> through the lines and intersect them with the overlapping polygons and
> sort them based on the length of the intersection fragments and limit
> 1 on the results.
> It just seems like this should be able to be done using join and
> sub-query of some kind, but I can't quite figure it out. Ultimately, I
> want to do an UPDATE line set attr1=b.someattr ...
> Thoughts,
>   -Steve
> postgis-users mailing list
