[postgis-users] Postgis -> Mapserver white background
David Fawcett david.fawcett at gmail.com
Wed Apr 27 07:02:06 PDT 2011
Ben's questions are good.
Often with MapServer, if you are getting a blank image, it is a
projection or extent issue.  Also, since you are setting your layer
status to default, you shouldn't need to specify any layers in your
cgi request.
It would also be useful to enable debugging in MapServer to determine
if MapServer is successfully retrieving features from the database.
There is more info about debugging here:
http://mapserver.org/optimization/debugging.html
David.
On Wed, Apr 27, 2011 at 3:13 AM, Graham Walker <gwalker84 at gmail.com> wrote:
> Thanks for the response Ben.
> I am accessing it through:
> http://127.0.0.1/cgi-bin/mapserv.exe?map=C:\ms4w\Apache\htdocs\test.map&layer=all&mode=map
> It just returns a blank png file.Currently, the table itself only
> contains one polygon, set with an SRID of 27700. The table has three
> columns in total, GID, name and the_geom. It was imported to
> postgreSQL using the shapefile and DBF loader. I can connect and get
> the polygon to display through QGIS without any issues through "adding
> a PostGIS layer" function.
> postgis.sql and spatial_ref_sys.sql have both been run.
> Is there anything else that might help? What do you require for me to
> attach the table definition?
> Thanks,
> On 27 April 2011 08:45, Ben Madin <lists at remoteinformation.com.au> wrote:
>> Graham,
>> It looks OK to me. Although the brevity is good, it might help if you could also attach the table definition - is it just producing a blank png image? is it in the same projection etc...? How are you accessing it (ie through WMS, mapscript or standard mapserver output).
>> I've also copied this back to MapServer list...
>> cheers
>> Ben
>> On 27/04/2011, at 3:26 PM, Graham Walker wrote:
>>> Hi all, fairly new to all this. I was wondering if you could help me
>>> with the following issue. I can't seem to display my postgis table in
>>> mapserver. I can display shapefiles and html templates fine, but when
>>> I try to connect to my postgis table I simply get a white background
>>> (or whatever colour I set it as).
>>> I have managed to display postgis tables before in mapserver, but I am
>>> having no luck in this one and cannot see any differences. Both the
>>> shapefile and postgis table can display in qgis. My map file is listed
>>> below. I have intentionally tried to simplify this down to the basics
>>> so it has no projection details, etc at present. Any help would be
>>> greatly appreciated.  Thanks
>>> MAP
>>> NAME "test"
>>> IMAGETYPE      PNG
>>>    SIZE 400 500
>>>    STATUS ON
>>>    EXTENT 200949 883531 347001 979508
>>>    SHAPEPATH "C:\ms4w\Apache\htdocs\test"
>>>    UNITS METERS
>>> END
>>>    WEB
>>>          IMAGEPATH "c:\ms4w\tmp\ms_tmp\"
>>>       IMAGEURL "/ms_tmp/"
>>>    END
>>> #Region Polygons
>>>    LAYER
>>>        NAME "North"
>>>        CONNECTIONTYPE postgis
>>>       CONNECTION "user=postgres password=1
>>>       dbname=test host=localhost port=5432"
>>>        DATA "the_geom from North"
>>>        TYPE POLYGON
>>>        STATUS DEFAULT
>>>        CLASS
>>>            STYLE
>>>                COLOR 1 1 1
>>>                OUTLINECOLOR 1 1 1
>>>            END
>>>        END
>>>    END
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
