[postgis-users] ST_Intersection(rast, the_geom) and ST_Intersects(rast, the_geom)
JP Glutting jpglutting at gmail.com
Thu Apr 28 04:39:06 PDT 2011
I am using postgis-2.0SVN (revision 7065, I think - I downloaded it on
Monday).
I am doing an analysis in which I need to test 50,000 points in a vector
table against a binary raster (with 0 set as NoData and 1 being the area of
interest). From what I can find online (Amazon has not sent my copy of
Postgis in Action yet), the following is the canonical way of doing this:
select V.id, ST_Intersection(R.rast, V.the_geom) as pts
from raster R, vector V
where ST_Intersects(R.rast, V.the_geom)
All I really need is:
select V.id
and I was hoping that it would be a faster way to do this.
However, when I run a test on my data, however, with "LIMIT 10", the
equivalent code takes 24,926 ms.
Doing something more complicated, like this (because ST_Intersection seems
to return empty geometries for the NoData areas):
select V.id, ST_IsEmpty((ST_Intersection(R.rast, V.the_geom)).geom) as ptest
LIMIT 10;
-- then I filter these results for ptest = FALSE
takes 589 ms.
I tried scaling this up to LIMIT 100 (359,304  and 6,444 ms, respectively)
and 1000 (1,980,397 and 61,628 ms).
This is a huge difference. Is this the best way to use
ST_Intersection/ST_Intersects? Am I doing something wrong here? Would I be
better off converting this to a vector? Any tips on optimizing this query
would be appreciated (I have to run the same query against several different
rasters, plus I want to understand how to do this right).
JP
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110428/fc7a8c82/attachment.html>
