[postgis-users] Geocoder (from extras)
Johnathan Leppert johnathan.leppert at gmail.com
Thu Apr 28 14:27:40 PDT 2011
Hi Regina,
Great, thanks! Do you want me to also send my changes for your review to the
linux version of the shell loader script? I fixed some syntax errors and
re-worked how it loops over files.
Thank you,
Johnathan
On Thu, Apr 28, 2011 at 5:00 PM, Paragon Corporation <lr at pcorp.us> wrote:
>  Jonathan,
> Sorry about that.  My fault.  I accidentally commented something out not
> intending to.
> The second function in that file should be
> CREATE OR REPLACE FUNCTION reverse_geocode(IN pt geometry, OUT intpt
> geometry[],
>     OUT addy NORM_ADDY[],
>     OUT street varchar[]) RETURNS RECORD
> AS
> -- default to not including street range in cross streets
>     SELECT reverse_geocode($1,false);
> language sql STABLE;
> I'll patch this in subversion.
> Thanks,
> Regina
> http://www.postgis.us
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Johnathan
> Leppert
> *Sent:* Thursday, April 28, 2011 4:14 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Geocoder (from extras)
> Yes I do, but my problem occurs when running the SQL to install the various
> functions into that schema. I had to comment out geocode/reverse_geocode.
> sql (which is included as part of create_geocode.sql) in order for the rest
> to install successfully.
> There appears to be a syntax error with the reverse_geocode function:
> psql:geocode/reverse_geocode.
> sql:101: ERROR:  return type mismatch in function declared to return record
> DETAIL:  Function's final statement must be SELECT or INSERT/UPDATE/DELETE
> RETURNING.
> CONTEXT:  SQL function "reverse_geocode"
> I'm not too familiar with writing them, so I'm not able to stop/debug the
> error. Any ideas?
> Thanks,
> Johnathan
> On Thu, Apr 28, 2011 at 4:09 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>  All the functions should have been installed in tiger schema.
>> Do you have a  tiger schema?
>> Leo
>> Leppert
>> *Sent:* Thursday, April 28, 2011 10:39 AM
>> *To:* postgis-users at postgis.refractions.net
>> *Subject:* [postgis-users] Geocoder (from extras)
>>   I fixed several bugs in the generated bash script to import US Census
>> shapefiles. Now I'm having an issue with the reverse geocoder SQL:
>> postgres at li63-206:/tmp/tiger_2010$ /usr/local/pgsql/bin/psql -d geo -f
>> ./create_geocode.sql
>> psql:./create_geocode.sql:4: ERROR:  schema "tiger" does not exist
>> BEGIN
>> psql:./create_geocode.sql:7: NOTICE:  type "norm_addy" does not exist,
>> skipping
>> DROP TYPE
>> CREATE TYPE
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> CREATE FUNCTION
>> psql:geocode/reverse_geocode.sql:101: ERROR:  return type mismatch in
>> RETURNING.
>> ROLLBACK
>> Anyone have any ideas? Using postgis-2.0.0SVN
>> Thanks,
>> Johnathan
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> *Johnathan*
> Software Architect & Developer
> Columbus, Ohio
> *Follow me on Twitter: @iamleppert <http://twitter.com/#%21/iamleppert>*
*Johnathan*
Columbus, Ohio
*Follow me on Twitter: @iamleppert <http://twitter.com/#!/iamleppert>*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110428/2fdede71/attachment.html>
