[postgis-users] converting to postgis
farouk azzouhri farouk153 at gmail.com
Fri Apr 29 01:32:43 PDT 2011
Hello,
I converted an Access database (contains two fields X and Y) in a .shp file
it's ok, but when I wanted to convert the .shp into a postgis database (
using the shp2pgsql-gui.exe ) it gives me the following message:
Unable to convert field name to UTF-8 (iconv reports "Illegal byte sequence"
). Current encoding is "UTF-8". Try "latin1 " (Western European), One Of The
gold values ​​at
http://www.postgresql.org/docs/current/static/multibyte.html Described.
Shapefile import failed.
how I'm going to do ??
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110429/f9bb7d69/attachment.html>
