[postgis-users] help with backing up and restoring a postgisdatabase (Raster comments)
Paragon Corporation lr at pcorp.us
Fri Aug 5 14:12:36 PDT 2011
Vishal,
P.S. - your raster notes are a good start. Haven't had a chance to read thru
to see if I can help with your questions at the end.
I would add a link to the PostGIS Raster manual section of the PostGIS docs
since that includes descriptions and examples for most of the functions.
It's still not quite complete but about 90% so.
http://www.postgis.org/documentation/manual-svn/RT_reference.html
Regina
http://www.postgis.us <http://www.postgis.us/>
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Vishal
Mehta
Sent: Thursday, August 04, 2011 8:11 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] help with backing up and restoring a
postgisdatabase
Hi all,
I am working with windows7/ postgres9.0.4/postgis2.0 which I recently
installed and started testing like so:
http://algoesalgo.wordpress.com/tag/postgis2-0/
my previous experience has been with postgres8.3/postgis1.5, and I have
never before now tried to backup and restore a postgres/postgis database
I am running into several errors when using pg_dump and pg_restore, and the
postgres documentation has raised some doubts in my mind as well. My
colleagues and I are trying to develop an application on one server which we
know we'll need to migrate next year, so we want to nail down the best way
to do this. Before I describe the kinds of errors specific to certain
attempts I've made (its quite confusing to keep track of for me), I'd like
to know if there are best practices regarding:
-      Pg_dump qns:
is it best to skip owner and priviliges (if say I want to havemy colleague
recreate my database sitting on localhost on my machine)
is it best to backup data only, skipping schema (same as above)
any other flags that are best set a certain way?
-       Psql dbname<infile, and pg_restore qns
-      I tried to create an empty database first, based on template0
Qn: Should this be based on template_postgis instead?
o    When I tried to restore my database called 'bangalore' and a schema
called 'mychema' using psql (with plain sql backup) into a couple of  empty
databases (because I did not want to mess up my database),
I got errors of various sorts, mainly:
Public.geometry does not exist;  myschema already exists
o     with pg_restore and a tarred backup , I tried to restore it into the
same 'bangalore' database (without deleting it first) and got errors that
the tables and schema already existed.
-      Finally I tried to just bring in the sql into the empty database
using the query window:
ERROR:  syntax error at or near "1"
LINE 282: 1 779330 1437291 BN1 6.5499999999999998 0101000020E6100000A3...
Which is referring to:
COPY borewells (gid, "UTM_X_", "UTM_Y_", "Code_No", "Water_Leve", geom) FROM
stdin;
0101000020E6100000A3FE0F26CC645340553700202FFA2940
I could really use some help,
Thanks,
Vishal
 <http://sei-us.org/about/staff_person/19> Vishal K. Mehta, Ph.D.
Staff Scientist,
Stockholm Environment Institute-US
400 F St, Davis, CA 95616
 <http://sei-us.org/> http://sei-us.org/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110805/e4a963b8/attachment.html>
