[postgis-users] Help dumping data from an old database
Ben Madin lists at remoteinformation.com.au
Tue Aug 16 18:14:02 PDT 2011
Chris,
This is probably a bad suggestion, but iff you are desparate and iff you can build a more recent postgis, then to dump it out you may find that creating a simlink from a more recent liblwgeom.so with the name of the missing one might work. the COPY command won't actually take anything other than the SQL, so shouldn't affect the importing.
cheers
Ben
On 17/08/2011, at 6:28 AM, Chris Gat wrote:
> Hello,
> I've recently been tasked with reviving an older database that hasn't been touch in a while. Both postgres and postgis were used to create this database. My ultimate goal at this point is to be able to dump the database from the linux server where it currently resides, to a mac workstation.
> Here is the short version of what I've done so far and the problem I'm having:
> build/install postgresql 8.2.3
> at this point, I can access the database (via psql, SELECT), but if I try to use pg_dump (pg_dump MYDB > MYDB.sql), I get the error:
> ERROR:  could not access file "$libdir/liblwgeom.1.2.so": No such file or directory
> STATEMENT:  COPY public.boundaries (gid, fnode_, tnode_, lpoly_, rpoly_, length, world_, world_id, bnd_type, bnd_status, bnd_study, area, len, the_geom) TO stdout;
> Obviously, after some investigation, I realize I need postgis. So I,
> build/install proj4 4.7
> build/install geos 3.1.1
> when I try to build postgis-1.2.1, I get the build error (after running make):
> lwgeom_geos_c.c: In function `postgis_geos_version':
> lwgeom_geos_c.c:84: warning: implicit declaration of function `VARATT_SIZEP'
> lwgeom_geos_c.c:84: error: invalid lvalue in assignment
> lwgeom_geos_c.c: In function `relate_full':
> lwgeom_geos_c.c:2073: error: invalid lvalue in assignment
> lwgeom_geos_c.c: In function `GEOS2LWGEOM':
> lwgeom_geos_c.c:2430: warning: assignment discards qualifiers from pointer target type
> lwgeom_geos_c.c:2439: warning: assignment discards qualifiers from pointer target type
> lwgeom_geos_c.c:2449: warning: assignment discards qualifiers from pointer target type
> lwgeom_geos_c.c:2450: warning: assignment discards qualifiers from pointer target type
> lwgeom_geos_c.c:2454: warning: assignment discards qualifiers from pointer target type
> lwgeom_geos_c.c:2455: warning: assignment discards qualifiers from pointer target type
> lwgeom_geos_c.c:2476: warning: assignment discards qualifiers from pointer target type
> lwgeom_geos_c.c: In function `polygonize_garray':
> lwgeom_geos_c.c:2815: warning: passing arg 1 of `GEOSPolygonize' from incompatible pointer type
> lwgeom_geos_c.c: In function `LWGEOM_buildarea':
> lwgeom_geos_c.c:2965: warning: passing arg 1 of `GEOSPolygonize' from incompatible pointer type
> lwgeom_geos_c.c:3008: warning: assignment discards qualifiers from pointer target type
> I can build/install postgis-1.3 and postgis-1.4, but these versions don't create the proper liblwgeom.so file.
> Any ideas as to why this is occurring would help greatly. I should also mention that the most important information in this database has nothing to do with postgis, therefore, if there is a way to ignore the tables associated with postgis, and thus avoid the liblwgeom requirement, that would suffice.
> Some additional information:
> -when configuring postgres, proj4, geos, I used --prefix=/mydirectory/
> -when configuring postgis, I used --prefix=/mydirectory/ --with-psql=/pathToPgconfig --with-geos=/pathToGeoConfig --with-proj=/mydirectory/
> Also, I use GNU make 3.8
> Thanks for you help, I appreciate it.
> Chris
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110817/5f24e952/attachment.html>
