[postgis-users] ERROR: geometry contains non-closed rings
Mr. Puneet Kishor punk.kish at gmail.com
Thu Aug 18 22:02:34 PDT 2011
On Aug 18, 2011, at 10:04 PM, Paul Ramsey wrote:
> I think you're going to have to write a little routine to close your
> rings... it looks like the WKB emitter is hard-coded to error out when
> asked to serialize broken things (hm???? I thought this was changed,
> the neverending story...)
For what its worth, I am using
"POSTGIS="1.5.3" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" USE_STATS"
As mentioned in my reply to Ben Madin's suggestion, when I run the following
	SELECT gid FROM data WHERE st_isclosed(the_geom) IS FALSE;
I get no results.
> You can patch it your self by changing this line
> http://trac.osgeo.org/postgis/browser/tags/1.5.3/postgis/lwgeom_inout.c#L307
> from PARSER_CHECK_ALL to PARSER_CHECK_NONE
> P.
> On Thu, Aug 18, 2011 at 9:19 AM, Mr. Puneet Kishor <punk.kish at gmail.com> wrote:
>> I loaded a bunch of data (that came from ArcMap) into PostGIS (1.5.3) via shp2pgsql and am trying to draw it with MapServer 6.0.1. I get
>>> msDrawMap(): Image handling error. Failed to draw layer named 'foo'.
>>> msPostGISLayerWhichShapes(): Query error. Error (ERROR: geometry contains non-closed rings )
>> Many thanks in advance for your suggestions.
>> Puneet Kishor
