[postgis-users] PostGIS Raster efficient enough to get height given coords from a large DEM?
Stefan Keller sfkeller at gmail.com
Fri Dec 2 11:17:55 PST 2011
Hi Bborie
2011/12/2 Bborie Park wrote:
> The question of tile size comes because the serialized raster data is
> stored in TOAST, which may compress the data.
Good point.
I know that a heap table is 8kb (unless changed in postgresql.conf)
and I assume that one wants to avoid that tuples have to use TOAST.
Are there any rules of thumb on how to estimate the tile size (in bytes)?
Yours, Stefan
2011/12/2 Bborie Park <bkpark at ucdavis.edu>:
> On Fri, Dec 2, 2011 at 8:15 AM, Stefan Keller <sfkeller at gmail.com> wrote:
>> In a server side program I'd like to get the height given a 2D lat/lon
>> coordinate.
>> The area covered is smaller than Europe with a resolution of at least
>> 25m. We'll take ASTER or SRTM as DEM/DTM data.
>> I know there are webservices like geonames' Elevation API (e.g.
>> http://api.geonames.org/astergdem?lat=50.01&lng=10.2&username=demo ).
>> But I'd like to know if this is feasible using PostgreSQL.
>> Is PostGIS Raster efficient enough to process and query such an amount of data?
>> Any experiences?
> Stefan,
> Assuming you test to see what the ideal (or "good-enough") tile size
> is for the elevation rasterset, you should see good performance using
> ST_Value(rast, ST_SetSRID(ST_MakePoint(long, lat), srid))
> You could eliminate the ST_SetSRID and ST_MakePoint by passing a
> correct EWKT instead
> ST_Value(rast, 'YOUREWKT'::geometry)
> -bborie
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
> postgis-users mailing list
