[postgis-users] PostGIS Raster efficient enough to get height given coords from a large DEM?
Bborie Park bkpark at ucdavis.edu
Sat Dec 3 22:45:33 PST 2011
On Sat, Dec 3, 2011 at 7:16 PM, Stefan Keller <sfkeller at gmail.com> wrote:
> Hi Bborie
> Many thanks for your response.
> To summarize: My goal is to get the height (in meters) given an
> arbitrary lat/lon coordinate from the latest free digital elevation
> model (like mentioned here
> http://slashgeo.org/2011/12/01/New-Free-Elevation-Dataset-named-Global-Multi-resolution-Terrain-Elevation-Data-2010-GMTE
> The approach using PostGIS to access raster data is
> 1st. to convert an ASCII GRID text file (an ESRI format) to GeoTIFF
> (not tiled nor "pyramide"-ized).
> Then (2nd) to load it into PostGIS, like described here
> http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01 .
I don't remember but I think GDAL supports ASCII GRID so you don't
need an intermediary file.  The loader uses GDAL to convert them into
the PostGIS Raster format.
> I still have some basic questions about this interesting approach:
> Regarding my question of "rules of thumb" in order to set the tile
> size you answered:
>> Generally speaking, the smaller the tile size, the faster the operation.  In
>> my testing of my rasters, 200x200 is slower than 100x100 which is slower
>> than 50x50.  The smaller tile size results in more rows in the table BUT the
>> performance dramatically increases.  I can't remember of the top of my head
>> but the performance gain was linear or better.
> Thats a good hint.
> Q1: But are there no calculcation rules on how to estimate an ideal
> absolute size (in pixels)?
Nope.  Testing is the only way as there are other possible factors
involved.  And even my estimates above are only guidelines.  I know
I'm going to have to test for my production database servers before I
know what works best for them.  In a pinch, I'd say you'd be happy
between 30 - 70.
> Regarding a query given lat/lon you proposed:
>> Assuming you test to see what the ideal (or "good-enough") tile size
>> is for the elevation rasterset, you should see good performance using
>> ST_Value(rast, ST_SetSRID(ST_MakePoint(long, lat), srid))
>> You could eliminate the ST_SetSRID and ST_MakePoint by passing a
>> correct EWKT instead
>> ST_Value(rast, 'YOUREWKT'::geometry)
> Q2: Given the raster has a resolution (grid) of - say at best - 30m,
> does this function really interpolate, given the input is an arbitrary
> coordinate (I can't find a hint to that in the docs
> (http://postgis.refractions.net/documentation/manual-svn/RT_ST_Value.html))?
There is no interpolation.  It literally is a pin stuck through the raster.
> Q3: If yes, I assume its linear. How could I proceed to get a result
> using non-linear interpolation (like Kriging)?
I don't know if you can using only PostGIS raster.  If you're able to
use PL/R as well, you should be able to tap into their kriging tools.
-bborie
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
