[postgis-users] spatial distribution maps (heat maps?)
Phil James borntopedal at yahoo.co.uk
Mon Dec 5 23:58:40 PST 2011
I would use something that is designed to do this analysis - R would be an obvious choice but there are others - using Python you can connect to Postgis to grab the data and then rpy to run R commands from python - we have used this configuration successfully using Django and it works fast enough for the web generating an image - this could of course be optimised to cache outputs if performance is an issue.
A synopsis of spatial functions in R is shown below:
http://cran.r-project.org/web/views/Spatial.html
Some sample code to run IDW below (just a hack but you get the idea).
import rpy2.robjects as robjects
import sys
#Create R stuff and load libraries
R = robjects.r
#R.library('sp')
R.library('gstat')
R.library('raster')
R.library('RPostgreSQL')
R("drv <- dbDriver('PostgreSQL')")
R("con <- dbConnect(drv, dbname='geoprocessing', user='postgres')")
R("rs <- dbSendQuery(con, 'SELECT x, y, value FROM randompts')")
R("na <- fetch(rs, n=-1)")
R("e <- na.omit(na)")
R("coordinates(e) <- ~x+y")
R("x.range <- as.integer(range(e at coords[,1]))")
R("y.range <- as.integer(range(e at coords[,2]))")
R("grd <- expand.grid(x=seq(from=x.range[1], to=x.range[2], bx=25), y=seq(from=y.range[1], to=y.range[2], by=25))")
R("coordinates(grd) <- ~x+y")
R("gridded(grd) <- TRUE")
R("idw.out <- idw(value~1, e, grd, idp=2.5)")
spplottext = "spplot(idw.out, \"var1.pred\", col.regions=topo.colors(20), pretty=TRUE)"
print(spplottext)
res = R(spplottext)
print(res)
sys.exit(0)
I am sure there are other solutions along the same lines.
Phil
>________________________________
> From: Puneet Kishor <punk.kish at gmail.com>
>To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Sent: Tuesday, 6 December 2011, 1:54
>Subject: Re: [postgis-users] spatial distribution maps (heat maps?)
>Steve,
>Thanks for your reply.
>On Dec 5, 2011, at 6:52 PM, Stephen Woodbridge wrote:
>> On 12/5/2011 6:45 PM, Puneet Kishor wrote:
>>> I am looking to create some heatmap-ish or DEM-ish spatial
>>> distribution visualizations. Any suggestions on how to go about doing
>>> so given a lon-lat containing geom column in PostGIS?
>> Create an empty raster. Then select your points and for each points and for each one "add" the sample dot centered on your location to to the raster. By "add", I mean you need to add the value of the pixels in the dot to the pixels in the raster. So raster=1 + dot=3 => raster=4 and limit it at maximum saturation. This should work for multiple channels also. This should give you a heat map.
>Reading the above made me realize that I should have rephrased my question -- I don't want to create images on the server side. I realize now that what I really want to do is to do spatial clustering on the server side and then send the data to the browser. I wrote my own very naive clustering routine in Perl, and also tried Algorithm::KMeans [1]. This kind of analysis allows me to create a summary of my data that I can then plot on the client (see image at [2]).
>Of course, my algorithm is way too naive, and waaaaay too slow, although I *can* compute the summary and cache it using Storable.
>So, here is my rephrased question -- I am looking to do spatial clustering on my Pg data. The added complication is that I do not have access to WKTRaster.
>[1] http://search.cpan.org/~avikak/Algorithm-KMeans-1.30/lib/Algorithm/KMeans.pm
>[2] http://dl.dropbox.com/u/3526821/occurrences.png
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111206/d6a5c1aa/attachment.html>
