[postgis-users] raster output
Paragon Corporation lr at pcorp.us
Wed Dec 21 13:54:03 PST 2011
Forgot to add if you want to output a whole table or a set of records as a
single raster, you'll want to also use the ST_Union function.
 So something like
SELECT ST_AddBand(ST_Reclass(ST_Union(rast) ....)
FROM yourtable
WHERE ST_Intersects(rast,somegeometry)
http://www.postgis.org/documentation/manual-svn/RT_ST_Union.html
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Paragon Corporation
> Sent: Wednesday, December 21, 2011 4:03 PM
> To: 'PostGIS Users Discussion'
> Subject: Re: [postgis-users] raster output
> Steve,
> Actually that was just for coloring geometries.  For raster I
> usually just output the raster as RGB
> R for band 1, G band 2, B for band 3
> If you have a single band raster, you'll need to do
> reclassify the bands if you want to out as PNG for example
> http://www.postgis.org/documentation/manual-svn/RT_ST_Reclass.html
> Look at the last example in the docs.
> Or you could just export as one of the gdal 1 Banded
> supporting formats and use QGIS to do the classification.
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> > Stephen Crawford
> > Sent: Wednesday, December 21, 2011 10:51 AM
> > To: PostGIS Users Discussion
> > Thanks for getting back to me.  I want to do something like
> #3, but I
> > just don't understand the work flow.  I have raw data as a one band
> > raster in postGIS, and the (seemingly) simple thing i would
> like to do
> > is output the entire table as a  jpg or png with the cells
> classified
> > by color.  I see references to "color tables" and
> "palettes".  I can't
> > seem to figure out where I can define "if cell val < 0.5,
> color = 0,
> > 0, 255" etc.
> > Thanks,
> > Steve
> > On 12/20/2011 6:13 PM, Paragon Corporation wrote:
> > > 3) You can use gdal_translate (compiled with PostgreSQL
> support) to
> > > output a postgis raster query.
> > Stephen Crawford
> > Center for Environmental Informatics
> > The Pennsylvania State University
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
