[postgis-users] Declarative SQL query for non-overlapping buffers given dense points?
Stefan Keller sfkeller at gmail.com
Mon Feb 14 11:58:31 PST 2011
I take the silence as an evidence that there is no declarative
solution to this challenge :->.
I think I have to write a stored procedure.
Yours, S.
2011/2/13 Stefan Keller <sfkeller at gmail.com>:
> Hi
> Given a table of peaks with the fields id, name, elevation, geom I'd
> like to write a query which returns to me only those (randomly
> selected) peaks - i.e. peak buffers say with radius 5 kilometers -
> which dont 'overlap'. This is motivated by a visualization use case
> where label names should'nt overlap because of lack of visual space -
> as well as because of low network capacity between db and client!
> Any ideas on how to solve this with a declarative SQL query?
> The only promising approach I found so far was is to define a subquery
> with ranked buffers and then to select some out of these...
> -S.
