[postgis-users] Upgrade using postgis_restore.pl
Yesid Carrillo Vega yecarrillo at gmail.com
Tue Feb 15 14:00:20 PST 2011
Armin.
This is OK. Those functions are deprecated now and probably you will
never use them.
Yesid Carrillo
On Tue, Feb 15, 2011 at 4:37 PM, Armin Burger <armin.burger at gmx.net> wrote:
> Hi all
> I needed to upgrade PostGIS together with Postgres, the versions were:
> Postgres: 8.3 -> 9.0
> PostGIS: 1.3 -> 1.5
> I followed the description in the Postgis docs for the "hard upgrade" using "postgis_restore.pl". It worked but I got a few error messages sent to stderr, like
> ERROR:  function st_histogram2d_in(cstring) does not exist
> ERROR:  could not access file "$libdir/liblwgeom": No such file or directory
> ERROR:  function public.asukml(geometry) does not exist
> These seem to correspond to messages with "KEEPING" written to the restore log , like
> KEEPING TYPE [histogram2d]
> KEEPING FUNCTION: [askml(geometry, integer, integer)]
> KEEPING FUNCTION: [asukml(geometry)]
> The database seems to work fine after the restore, and so far I have not found any problems. Can I silently ignore those errors (the docs don't say anything how I should handle the "KEEPING..." messages). To me the functions causing errors and KEEPING messages look like they're not included any more in Postgis 1.5 (the KEEPING messages are written out also for custom procedures).
> Thanks in advance for any clarifications
> Armin
