[postgis-users] regarding count query on multiple column in one go
Yamini Singh yaminijsingh at live.com
Thu Feb 24 08:19:02 PST 2011
Hi All,
I have a table hydro_net in PostGIS database. The table has
following schema:
CREATE TABLE public.hydro_net
(hid integer NOT NULL DEFAULT
nextval,
f_code_des varchar(254),
hyd_desc varchar(254),
hyd_name varchar(254),
geom geometry,
I have more than 3000 records in this table and some records
have multiple hyd_name but with the same geometry. I can count the hyd_name
with a simple query to get the hyd_name and the count as under:
select hyd_name, count(*)
from hydro_net
group by hyd_name
having count(*) > 1
order by hyd_name;
I would like to know if it is possible to get the table out
all the columns in the original table with the records of duplicate hyd_name
and its count.
I am not really getting how to write a query that count the
hyd_name and also returns all column information as well at least hyd_name,
geom and count.
Would really appreciate any help.
Thanks,
Yamini
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110224/06b5b805/attachment.html>
