[postgis-users] Build PostGIS 1.5.2 under Windows
Ilie, Radu rilie at wsi.com
Wed Jan 19 05:27:14 PST 2011
I am not familiar with the MingW builds. If we do use them, will the
resulting dll's have any dependencies on any runtime component of MingW?
Or can we simply take the resulting dll's (for postgis, geos, proj etc)
and copy them to another Windows system that doesn't have any part of
MingW installed?
Radu
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, January 19, 2011 6:20 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Build PostGIS 1.5.2 under Windows
On 18/01/11 19:39, Ilie, Radu wrote:
> Hi,
> We need to build PostGIS 1.5.2 as 32 bit under Windows, using Visual
C++.
> We tried to follow the instructions from
> http://trac.osgeo.org/postgis/wiki/DevWikiWinVC_15, but the
instructions
> from there are not complete. We tried to follow the logical path from
> the end of the instructions, but we get thousands of compilation
errors.
> I noticed at http://www.postgis.org/download/windows/experimental.php
> that there are binaries available for distribution under Windows. I
> imagine the people building them have a build environment for Windows
> already set up. Does anybody know the steps followed by the people
that
> build the Windows binaries?
> Are there any updated instructions available for building PostGIS
under
> Windows? Even if they are cumbersome, we can follow them.
> Thank you,
Sadly MSVC builds under Windows are currently unsupported, however if
you do manage to get any further please do update the wiki with your
progress. Is there any particular reason that you can't use the MingW
builds?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
