[postgis-users] Basic cookie cutting of polys with polys
lplateandy andy at centremaps.co.uk
Tue Jul 5 13:24:42 PDT 2011
Hi Andy,
I wouldn't like to guarantee that we know the best methods but i have found
ST_Intersection to be very effective and fast. By querying one table with a
polygon from another, it's been a doddle to either view a tabular result in
pgAdmin (and export etc) or (as a cadcorp software user) to set up a "VIEW"
using the same query set up in pgAdmin which can then be worked with as a
layer is SIS. Had no problem handling significant datasets.
Give me a shout if you'd like a chat.
Andy
Andrew Terry
centremapslive.com
01886 834809
Andrew Kemp-2 wrote:
> Hello,
> I am getting confused after reading previous posts as to whether I should
> be looking for Difference, Symdifference or a straight forward
> ST_Intersection.
> I am trying to cut the polygons in overlay POSTCODES with the polygons in
> overlay CUTTER and keep all the attributes from POSTCODES in the resultant
> output.  Both overlays I have decomposed so there are no multi-polygon
> items.
> Is there a simple way to achieve this? And which method should I be using?
> Many thanks for all your support
> Andy
> This email is confidential and may be privileged and should not be used,
> read
> or copied by anyone who is not the  original intended recipient. If you
> have
> received this email in error  please inform the sender and delete it from
> your mailbox or any other storage mechanism. Unless specifically stated,
> nothing in this email constitutes an offer by Cadcorp and Cadcorp does not
> warrant that any information contained in this email is accurate.
> Cadcorp cannot accept liability for any statements made which are clearly
> the
> sender's own and not expressly made on behalf of Cadcorp or one of its
> agents.
> Please rely on your own virus check. No responsibility is taken by Cadcorp
> for any damage arising out of any bug or virus infection.
> postgis-users mailing list
View this message in context: http://old.nabble.com/Basic-cookie-cutting-of-polys-with-polys-tp31997104p32000126.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
