[postgis-users] Newbie ST_World2RasterCoordX, ST_World2RasterCoordY Band Values nested loop to iterate over raster
Chris English emailchrisenglish at gmail.com
Sat Jul 9 10:00:37 PDT 2011
I am trying to iterate over a raster, extract World2RasterCoordX/Y and Band
Values using the following function:
Create or replace function extract_as_text(rast raster) returns text as
Declare
 i int;
 j int;
rast raster;
Begin
for i in 1..2048 loop  --dim x
for j in 1..1536 loop -- dim y
select ST_world2rastercoordx(rast, i, j) as xcoord,
St_world2rastercoordy(rast, i, j) as ycoord,
ST_value(rast,1, i, j) as R,
ST_value(rast, 2, i, j) as G,
ST_value(rast, 3, i, j) as B
from rbike_all;
End loop;
End loop;
return xcoord,ycoord,R,G,B; <- this part is probably not right either -
should perhaps just say text
end;
Language 'plpgsql'
Query returned successfully with no result in 15 ms.
Select extract_as_text(rast)
from rbike_all;
ERROR:  column reference "rast" is ambiguous
LINE 1: select ST_world2rastercoordx(rast, i, j) as xcoord,
DETAIL:  It could refer to either a PL/pgSQL variable or a table column.
QUERY:  select ST_world2rastercoordx(rast, i, j) as xcoord,
from rbike_all
CONTEXT:  PL/pgSQL function "extract_as_text" line 9 at SQL statement
********** Error **********
SQL state: 42702
Detail: It could refer to either a PL/pgSQL variable or a table column.
Context: PL/pgSQL function "extract_as_text" line 9 at SQL statement
Removing rast from Declare above  results in the same error.
Any pointers greatly appreciated.
Chris
He doesn't fully understand what he thinks he knows about the problem.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110709/2ac1d499/attachment.html>
