[postgis-users] Newbie Geocoding Error
Paragon Corporation lr at pcorp.us
Sun Jul 10 12:27:47 PDT 2011
Steve,
Hmm didn't realize Camino is a prefix type.  So that would be a tiger
geocoder problem since I don't think we have any logic to deal with prefix
types that aren't directions.
So this is a somewhat similar issue to the Saint vs. St . Problem we already
have logged, though a little different.
So looks like it's just known as  Del Rio (as far as streetnames go in
database with streetpreabbrev being Cam).
So if I run this:
SELECT (addy).*, ST_ASText(geomout) from geocode('477 del Rio South, San
Diego, CA 94115')
I get similar set of answers you get.
And as you stated, the first hit has a 92108 zip.
I'll log this one as a ticket.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Woodbridge
Sent: Sunday, July 10, 2011 10:34 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Newbie Geocoding Error
Hi Michael,
This may be a Tiger data problem. I have Tiger2010 data loaded in PAGC
geocoder and here are the results:
http://tinyurl.com/3zd2fwu
You will notice that the 94115 zipcode does not show up. How do the first
two responses line up with your expected results?
I would try your request again and leave off the zipcode. In general the
zipcode data in Tiger is somewhat hit and miss as the zipcodes have changed
over time since they were first introduced.
-Steve
On 7/10/2011 9:58 AM, Michael Papet wrote:
> Regina,
> Thanks for your help. I updated postgis install to the later SVN as
> linked on the site and had a couple of observations,
> 1. the upgrade_geocoder script ran with most of the sql returning
> 'already exists' errors. Do I need to modify the script to drop before
> recreating?
> 2. My original error went away.
> So, now onto another address that does not geocode. The results don't
> even include the street in the query.
> 477 Camino del Rio South, San Diego, CA 94115
> SELECT * from normalize_address returns address predirabbrev
> streetname streettypeabbrev postdirabbrev internal location
> stateabbrev zip parsed
> 477 <null> Camino del Rio <null> S <null> San Diego CA 94115 true
> I don't have enough knowledge of postGIS right now to know if it's a
> bug or operator error.
> Thanks again.
> Michael
> Message: 10
> Date: Sat, 9 Jul 2011 14:23:09 -0400
> From: "Paragon Corporation" <lr at pcorp.us <mailto:lr at pcorp.us>>
> To: "'PostGIS Users Discussion'"
> <postgis-users at postgis.refractions.net
> <mailto:postgis-users at postgis.refractions.net>>
> Message-ID: <20AE3B391EAA4F1A8CBE0347002383E2 at J>
> Content-Type: text/plain; charset="us-ascii"
> Mike,
> Which version are you running with? For the newer ones -- if you look
> at the normalize_address function , you should see a stamp in the
> beginning of the code that has
> --$Id: normalize_address.sql 7616 2011-07-07 12:41:13Z robe $-
> That is the latest version stamp. Really old versions don't even have
> a stamp. If you are running something older than a week or 2 ago, that
> is probably why you are having these issues.
> The easiest way to upgrade to the latest is:
> 1) Download the PostGIS 2.0 tar ball from here --
> http://www.postgis.org/download/ (the tiger_geocoder is in
> extras/tiger_geocoder/tiger_2010)
> -- (This new version requires PostGIS 1.5+ and PostgreSQL 8.4+)
> 2) Edit the upgrade_geocoder.sh file with your postgres settings and
> then run it.
> 3) Run the Missing_indexes_Generate_Script() to get the commands to
> build indexes you may be missing.
> http://www.postgis.org/documentation/manual-svn/Missing_Indexes_Genera
> te_Scr
> ipt.html
> and then execute that generated script
> I think this is a bug I might have fixed. When I run normalize on this
> I don't get an error, and yours seems to be breaking in the normalize
step.
> When I run
> SELECT * FROM normalize_address('3261 South West 160 Avenue, Miramar,
> FL
> 33027')
> I get the below
> address | predirabbrev | streetname | streettypeabbrev | postdirabbrev
> | internal | location | stateabbrev | zip | parsed
> 3261 | SW | 160 | Ave |
> | Miramar | FL | 33027 | t
> Unfortunately I don't have Florida data loaded so can't tell if it
> will geocode right or not.
> Regarding bad rating results, the issue is often what the address gets
> normalized to and a bad normalization is often the cause of bad
> geocoding results. So probably the best check to do is do a simple
> SELECT * FROM normalize_address(...);
> and see what it comes with and if that normalized addess makes sense.
> There are many cases where it doesn't that I have fixed recently and
> some more that are known bugs I am working on. Check out the list of
> issues and closed ones for details:
> http://trac.osgeo.org/postgis/query?component=tiger+geocoder
> The other issue I see with your code -- which perhaps it was for
> testing, is that you are normalizing twice.
> You should just be doing a:
> geocode('3261 South West 160 Avenue, Miramar, FL 33027')
> No need for those extra steps.
> You might want to take a look at the manual for recent improvements
> made too and examples:
> http://www.postgis.org/documentation/manual-svn/Geocode.html
> Hope that helps,
> Regina
> http://www.postgis.us <http://www.postgis.us/>
> postgis-users mailing list
