[postgis-users] Merging points in right order
George Washington gws293 at hotmail.com
Wed Jul 13 00:34:14 PDT 2011
Hi, I have some considerable difficulty with the following problem:
I have a LINESTRING table with walking tracks
I have a MULTILINESTRING table with contours (with elevation attribute).
I can successfully get the points of intersection between tracks and contours to obtain the elevation and coordinates at the point of intersection.
What I need to do next, and I don't know how, is to merge the points of intersection for a given track with the track linestring, i.e. add the intersection points to the track linestring (or create a new track which includes the intersection points). However the intersection points have to be inserted in the right position in the track linestring, not just at the front, as ST_LINEMERGE() seems to do. The reason is I need then to traverse the track, point by point, to obtain the distance between points.
Any suggestions will be most welcome, thank you.
George
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110713/52e41a85/attachment.html>
