[postgis-users] Shapefiles exported from PostGIS and ESRI ArcView 9 compatibility
Paul Ramsey pramsey at opengeo.org
Thu Jul 21 08:08:24 PDT 2011
There's no reason to think the Shape files produced by shp2pgsql won't
work in any and all versions of Arc.
P
On Thu, Jul 21, 2011 at 12:23 AM, Ben Madin
<lists at remoteinformation.com.au> wrote:
> G'dat all,
> We have a client (potential client) who wants some mapping done and the maps returned in shapefile format. In the contract they insist on specifying that the shapefiles are compatible with "ESRI's ArcView version 9" (their words, not mine).
> I don't have "ESRI's ArcView version 9", and don't intend on spending that sort of money (more than the contract is worth). However, I'm sure that if what we send back doesn't open in "ESRI's ArcView version 9" it will become our problem.
> Does anyone have any reason to suspect that a shapefile created using valid OGC geometry in PostGIS and exported using pgsql2shp would not or might not work on "ESRI's ArcView version 9"?
> Are there any issues that someone who is across platforms can help me with?
> (I routinely use shapefiles created using valid OGC geometry in PostGIS and exported using pgsql2shp in QGIS and MapServer and send them to other people, so I have no reason to be concerned except that the client insists on this line remaining the contract!)
> cheers
> Ben
> postgis-users mailing list
