[postgis-users] Follow-up: exterior rings in multipolygons
Mr. Puneet Kishor punk.kish at gmail.com
Mon Jul 25 16:23:45 PDT 2011
On Jul 25, 2011, at 4:16 PM, Mr. Puneet Kishor wrote:
> On Jul 25, 2011, at 3:44 PM, Sandro Santilli wrote:
>> On Mon, Jul 25, 2011 at 03:40:34PM -0500, Mr. Puneet Kishor wrote:
>>> Please help me understand the following
>>> SELECT
>>>   ST_Nrings(the_geom) nr,
>>>   ST_NumInteriorRings(the_geom) nir,
>>>   ST_AsText(the_geom) WKT
>>> FROM table
>>> WHERE objectid = 280;
>>> nr  nir  WKT
>>> 4    3  "MULTIPOLYGON(((..),(..),(..),(..)))"
>>> Looking at the above, I am assuming the first (..) is the exterior ring, and the remaning three (..) are the 3 interior rings. However,
>>> SELECT ST_ExteriorRing(the_geom) er
>>> FROM table
>>> ERROR: ExteriorRing: geom is not a polygon
>>> So, what is going on? Of course, the docs say that ST_ExteriorRing doesn't work on a MULTIPOLYGON. So, is the above only an implementation anomaly, and I can treat the first ring as an exterior ring? Or, is it really something else?
>> All your rings are wrapper in another pair of parens, which identify
>> a component of the MULTIPOLYGON, that is a POLYGON. You must extract
>> the Polygon to use ST_ExteriorRing against it. So your query would be:
>> SELECT ST_ExteriorRing(ST_GeometryN(the_geom,1)) er
>> FROM table
> Thanks. The above works. So, does this mean that given "MULTIPOLYGON(((1),(2),(3),(4)))", 1 indeed is an exterior ring, and 2-4 are interior rings, and the "entity" does have 4 rings kinda like below?
> |  |     |   | 3 |  |
> |  |  2  |   +---+  |
> |   1   |   4    |  |
Pursuing my quest to understand how multipolygons are handled
SELECT
    ST_AsText(the_geom) wkt_feature,
    ST_AsText(ST_ExteriorRing(ST_GeometryN(the_geom, 1))) wkt_ext_ring
FROM table
WHERE id = 280;
nr  nir  wkt_feature                          wkt_ext_ring
 4    3  MULTIPOLYGON(((..),(..),(..),(..)))  LINESTRING(..)
So, the exterior ring is not a polygon. It is actually a LINESTRING. How can that be? And, how do get the geometries of the rest of the rings? The following doesn't work (for, say, ring 2)
	ST_AsText(ST_InteriorRingN(the_geom, 2))
I get "ERROR:  InteriorRingN: geom is not a polygon". And, the following
	ST_AsText(ST_InteriorRingN(ST_GeometryN(the_geom, ?)))
I get "ERROR:  function st_interiorringn(geometry) does not exist"
For what its worth, this table has only what I would consider polygons, no lines. I loaded it via shp2pgsql without forcing it to load POLYGONS. I believe, by default, it creates MULTIPOLYGONS.
