[postgis-users] Shapefiles exported from PostGIS and ESRI ArcView 9 compatibility
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jul 26 06:09:04 PDT 2011
On 7/25/2011 10:52 PM, Paragon Corporation wrote:
> Steve,
> Is your pgsql2shp not exporting .prj files?  It should be if you are
> exporting an sql query or table/view with a known srid and all records have
> the same srid. It should be doing this from version PostGIS 1.3.6 on.  I
> wrote that logic because I had similar issues with users using ArcMap not
> being able to overlay the exports with their other data layers.
> Thanks,
> Regina
> http://www.postgis.us
Hmmm, I recently upgraded and just now checked and yes it is writing the
.prj file.  Sorry for old information and glad to know you are on top of
these issues.
RCSID: $Id: pgsql2shp.c 5181 2010-02-01 17:35:55Z pramsey $ RELEASE: 1.5
USE_GEOS=1 USE_PROJ=1 USE_STATS=1
Thanks,
   -Steve
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
> Woodbridge
> Sent: Monday, July 25, 2011 9:17 PM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Shapefiles exported from PostGIS and ESRI
> On 7/21/2011 3:23 AM, Ben Madin wrote:
>> G'dat all,
>> We have a client (potential client) who wants some mapping done and
>> the maps returned in shapefile format. In the contract they insist on
>> specifying that the shapefiles are compatible with "ESRI's ArcView
>> version 9" (their words, not mine).
>> I don't have "ESRI's ArcView version 9", and don't intend on spending
>> that sort of money (more than the contract is worth). However, I'm
>> sure that if what we send back doesn't open in "ESRI's ArcView
>> version 9" it will become our problem.
>> Does anyone have any reason to suspect that a shapefile created using
>> valid OGC geometry in PostGIS and exported using pgsql2shp would not
>> or might not work on "ESRI's ArcView version 9"?
>> Are there any issues that someone who is across platforms can help me
>> with?
>> (I routinely use shapefiles created using valid OGC geometry in
>> PostGIS and exported using pgsql2shp in QGIS and MapServer and send
>> them to other people, so I have no reason to be concerned except that
>> the client insists on this line remaining the contract!)
> Hi Ben,
> I use ArcGIS Explorer and it will not open shapefiles that do not have
> .prj file. What I do in this case if to just write a script that
> generates that appropriate .prj that I need. The other option that might
> be work better for you is to use ogr2ogr to export the postgis table
> into a shapefile as I believe that will write the .prj file appropriately.
> -Steve W
> postgis-users mailing list
