[postgis-users] calling postgis functions from jdbc
Smith Roman autisi at yahoo.com
Tue Jul 26 12:58:13 PDT 2011
Hello guys,
I want to execute the postgis function ST_Within from a java application using jdbc. My function executes successfully but I am not getting the result I am expecting. My function returns false when it should be true. Since I am able to view the point and polygon features in udig. (The point is actually within the polygon).  I want to do a point in polygon test i.e. test if a point feature is within a polygon feature. The two layers use epsg 4326.
Here is the code I am using. I will like to know if my code is okay:
public ArrayList<SearchResultDTO> searchTown(String town, String state)
        ArrayList<SearchResultDTO> searchResults = new ArrayList<SearchResultDTO>();
        SearchResultDTO searchResultDTO = null;
           query = "select a.gid, a.the_geom from places a where name like ?";
        try {
            logger.info(query);
          PreparedStatement prepstmt = pgCon.prepareStatement(query);
            prepstmt.setString(1, town + "%");
            //prepstmt.setString(2, state);
           ResultSet rset = prepstmt.executeQuery();
            while (rset.next()) {
              PGgeometry geom = (PGgeometry)rset.getObject(2);
               containedInState(geom, state);
                searchResultDTO = new SearchResultDTO();
                //result = true;
               searchResultDTO = getTown(rset.getInt(1));
               searchResults.add(searchResultDTO);
            rset.close();
            prepstmt.close();
        } catch (SQLException e) {
            logger.info(e.getMessage());
            e.printStackTrace();
        return searchResults;
public boolean containedInState(PGgeometry pgGeometry, String state)
    Boolean result = null;
    CallableStatement upperProc = null;
           query2 = "{ ? = call ST_Within(?, ?) }";
          query = "select b.the_geom from nglga b where b.statename = ? limit 1";
          logger.info(query);
        try {
            prepstmt.setString(1, state);
           if ( rset.next() )
             PGgeometry geom = (PGgeometry)rset.getObject(1);
             logger.info(query2);
            upperProc = pgCon.prepareCall(query2);
            upperProc.registerOutParameter(1, Types.BOOLEAN);
            upperProc.setObject(2, pgGeometry);
            upperProc.setObject(3, geom);
           //  upperProc.setObject(2, geom);
           // upperProc.setObject(3, pgGeometry);
            upperProc.execute();
            result = upperProc.getBoolean(1);
            if (result)
             logger.info("outcome: true " );
            else
              logger.info("outcome: false " );
           upperProc.close();
            rset.close();
    return result;
 public Connection getPostGISConnection() throws Exception
        Connection con = null;
         String url = "jdbc:postgresql://192.168.56.130:5432/postgis";
        logger.info(" Get postgis database connection ......... ");
          //  DriverManager.registerDriver(new oracle.jdbc.driver.OracleDriver());
        //url = "jdbc:oracle:thin:@" + hostName + ":" + portNo + ":" + sid;
          Class.forName("org.postgresql.Driver");
          con = DriverManager.getConnection(url, "postgres", "test");
          ((org.postgresql.PGConnection)con).addDataType("geometry","org.postgis.PGgeometry");
          ((org.postgresql.PGConnection)con).addDataType("box3d","org.postgis.PGbox3d");
            logger.info("postgis database connection successful ! ");
        return con;
