[postgis-users] exterior rings in multipolygons
Mr. Puneet Kishor punk.kish at gmail.com
Wed Jul 27 04:33:30 PDT 2011
On Jul 27, 2011, at 1:06 AM, Ben Madin wrote:
> G'day Puneet,
> I've attached a picture of what I see - 280.shp is in fact two polygons - the top one is 280 and the bottom one 531. The numbers in black are the shapefile, those in red the postgis connection.
> I hope this helps somewhat.
It helps tremendously. For now, all this may simply have been a user-error (but, the plus side is, I learned quite a lot). But, I will continue to investigate as to why in ArcMap it selected "two" features when I selected only one. Got to make sure stuff is coming out of Arc correctly.
Puneet.
