[postgis-users] Where does Postgres end and PostGIS begin?
Aren Cambre aren at arencambre.com
Wed Jul 27 08:28:54 PDT 2011
I looked into this more, and I'm guessing the answer is "yes".
Looks like PostGIS 1.5.3 can be used with Postgres 9.1 beta.
I assume that the index used by Postgres has no bearing on how PostGIS
performs. Is this true? However, it may not be true because Postgres will
need additional support from PostGIS to handle GIST indexes on geometry
objects?
Aren
On Mon, Jul 25, 2011 at 2:39 PM, Aren Cambre <aren at arencambre.com> wrote:
> Will PostGIS have a release that supports Postgres 9.1 and the new GIST
> index when 9.1 comes out?
> Aren
> On Mon, Jul 25, 2011 at 2:34 PM, forkandwait <forkandwait at gmail.com>wrote:
>> Ragi Burhum <rburhum <at> gmail.com> writes:
>> > Brent and Sean are correct. Nevertheless, it is worth noting that if you
>> are
>> trying to do k nearest neighbor queries, PostgreSQL 9.1 has  much better
>> (as in
>> orders of magnitude) indexing support for this particular scenario.
>> See http://www.depesz.com/index.php/2010/12/11/waiting-for-9-1-knngist/
>> It is worth noting that the "geometry" native to postgres is very useful
>> for
>> building tricky multidimensional indices and getting distances in a sort
>> of
>> "state space" analysis.
>> For actual mapping of stuff on the ground, Postgis is way more
>> appropriate.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110727/bb7be0a7/attachment.html>
