[postgis-users] Mapserver connection to Postgis Raster
Virginia Maffei vmaffei at gmail.com
Thu Jun 2 14:36:49 PDT 2011
Hola! estoy intentando cargar manualmente el raster support y estoy
ejecutando el rtpostgissql que trae el postgis2.0
Pero al ejecutarlo me tira que no existe la funcion box2d(raster)
Alguna idea de que puede estar pasando?
Gracias!
PD: Escribí en español porque me pareció ver que son de españa y yo en
realidad hablo en español.
saludos!
Virginia
On Thu, Jun 2, 2011 at 11:16 AM, Virginia Maffei <vmaffei at gmail.com> wrote:
> Thank you!! I will try that installation
> Virginia
> 2011/6/2 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> On Thu, Jun 2, 2011 at 3:25 PM, Virginia Maffei <vmaffei at gmail.com>
>> wrote:
>> > Thank you for your quick response!
>> > I have another question: can i install postgis 2.0 in windows? where can
>> I
>> > download it?
>> > Virginia
>> Yes, you can. Follow this post's instructions:
>> http://gis4free.wordpress.com/2011/03/10/how-to-install-and-configure-postgis-raster-on-windows/
>> Best regards,
>> Jorge
>> >> Hi,
>> >> The mode=2 parameter is only valid with the last version of GDAL
>> >> (1.8.0). So, as Regina said, you need that version to make it work
>> >> properly. More accurately:
>> >> - With a GDAL version down to 1.7.1, you can't make it work in any
>> >> way. No driver.
>> >> - With a GDAL version between 1.7.1 and 1.7.3, both included, you can
>> >> use the old version of the driver, thought to work with the old
>> >> wktraster extension, now abandoned. And it was buggy. Not recommended.
>> >>  Neither GDAL 1.7.x nor wktraster.
>> >> - With GDAL version up to 1.8.0, you can use the last version of GDAL
>> >> PostGIS Raster driver, and you'll need PostGIS 2.0, that includes
>> >> PostGIS Raster extension. Additionally, as Regina said, those days
>> >> we're working on the driver, and all the improvements will be included
>> >> in GDAL 1.8.x
>> >> So, summarizing: You need PostGIS 2.0 plus GDAL 1.8.0 to make it work.
>> >> Further information on the driver:
>> >> http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html
>> >> Best regards,
>> >> Jorge
>> >> On Thu, Jun 2, 2011 at 6:53 AM, Paragon Corporation <lr at pcorp.us>
>> wrote:
>> >> > Virginia,
>> >> > I think you are missing a mode='2'  in your connection.  That was a
>> new
>> >> > requirement that was added for GDAL 1.8+
>> >> > Try putting that in.  I think the speed on the loading still needs
>> quite
>> >> > a
>> >> > bit of work though last I tried.  The speed issues will hopefully be
>> >> > resolved before 2.0 release.
>> >> > Thanks,
>> >> > Regina
>> >> > http://www.postgis.us
>> >> > ________________________________
>> >> > From: postgis-users-bounces at postgis.refractions.net
>> >> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> >> > Virginia
>> >> > Maffei
>> >> > Sent: Wednesday, June 01, 2011 8:00 PM
>> >> > To: postgis-users at postgis.refractions.net
>> >> > Subject: [postgis-users] Mapserver connection to Postgis Raster
>> >> > Hi, i'm new at this and i'm trying to connect to postgis raster in
>> the
>> >> > mapfile.
>> >> > I loaded a tif file into postgis raster database with the
>> >> > raster2pgsql.py
>> >> > script. It created a table with 2 fields: rid and rast.
>> >> > In the mapfile i added the connection like it specifies in the
>> postgis
>> >> > raster FAQ but it doesn't displays anything.
>> >> > This is my mapfile:
>> >> > MAP
>> >> >   IMAGETYPE      PNG24
>> >> >   EXTENT         366582.2901411663 6127927.100382689
>> 857582.2901411663
>> >> > 6670927.100382689
>> >> >   SIZE           491 543
>> >> >   SHAPEPATH      "../data"
>> >> >   LAYER # MODIS raster layer begins here
>> >> >     NAME         modis
>> >> > TYPE         RASTER
>> >> > STATUS       ON
>> >> > DATA "PG:host=localhost port=5432 dbname='postgis' user='postgres'
>> >> > password='postgres' schema='public' table='HumedadDeExtincion'"
>> >> >     PROCESSING "NODATA=0"
>> >> > PROCESSING "SCALE=AUTO"
>> >> > PROCESSING "SCALE_BUCKETS=201"
>> >> >     PROCESSING   "BANDS=1"
>> >> >     OFFSITE      71 74 65
>> >> > CLASS
>> >> > NAME "red"
>> >> > EXPRESSION ([pixel] < 10)
>> >> > COLOR 255 0 0
>> >> > END
>> >> > CLASS
>> >> > NAME "green"
>> >> > EXPRESSION ([pixel] >= 10 AND [pixel] < 15000 )
>> >> > COLOR 0 255 0
>> >> > END
>> >> > CLASS
>> >> > NAME "blue"
>> >> > EXPRESSION ([pixel] >= 15000 )
>> >> > COLOR 0 255 0
>> >> > END
>> >> >   END # MODIS raster layer ends here
>> >> >   # End of LAYER DEFINITIONS -------------------------------
>> >> > END # All map files must come to an end just as all other things must
>> >> > come
>> >> > to...
>> >> > I have gdal 1.6 , postgis 1.5 and ms4w with mapserver 5.6.6
>> >> > We cant see the tiff file on the browser, it only appears a white
>> image.
>> >> > We did try with the tif without the database connection an it works.
>> >> > Could you help us?
>> >> > Thank you
>> >> > _______________________________________________
>> >> > postgis-users mailing list
>> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> >> Jorge Arévalo
>> >> Internet & Mobilty Division, DEIMOS
>> >> http://es.linkedin.com/in/jorgearevalo80
>> >> http://mobility.grupodeimos.com/
>> >> http://geohash.org/ezjqgrgzz0g
>> Jorge Arévalo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110602/55c9c4d4/attachment.html>
