[postgis-users] Eclipse DBViewer plugin for postgis
George Washington gws293 at hotmail.com
Mon Jun 6 16:23:23 PDT 2011
Hi i was wandering if anybody had succeeded in using the DBViewer plugin for Eclipse with Postgis (1.5.0).
I have so far only been able to view the database structure but not to execute any SQL, and that is I think because it does not recognise the PostGIS driver. (Error I get when I select the Postgis jar file is "The Driver class doesn't exist in specified ClassPath", but if I select the Postgresql jar file it does recognise the driver class)).
 I am aware that pgAdmin can do it but I use Eclipse with Python to access the database and it would be handy to test SQL from the DBViewer itself.
thank you
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110606/4ed56ce1/attachment.html>
