[postgis-users] Extract boundary from multipoint
Nicklas Avén nicklas.aven at jordogskog.no
Tue Jun 7 03:48:23 PDT 2011
Hallo
What is not working?
ST_ConvexHull only calculates in 2D but since it passes the z-values to
the result it should work if your plane is coplanar and not vertical.
If it is a vertical plane only one point per 2d point will be
considered.
But as long as each point has its own representaion in 2D xy plane it
should work as I understand it.
/Nicklas
On Tue, 2011-06-07 at 12:25 +0200, sdellyta at hsr.ch wrote:
> Hi,
> I would like to ask a question :
> I have set of point clouds and managed to do the segmentation. From the segmentation I have set of points that define a plane. Anyone know how to get the boundary of the plane?
> It seems that convex hull does not really work in my case.
> Thanks.
> sdellyta
> postgis-users mailing list
